Old 11-10-2004, 06:34 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Big 16g vs Small 16g
Ok i want to buy a new turbo this winter and the other day a guy at a performance shop was telling me to go with the small 16 g because im AWD. He said the big 16g would lag up to much being AWD. Is this true? Or is he a moron?
Old 11-10-2004, 06:52 PM
Savior1974's Avatar
Savior1974 Savior1974 is offline
Re: Big 16g vs Small 16g
..................... moron. complete utter moron. Turbo's will lag just as much on a FWD as on a AWD. Actually, we AWDers are better with turbos with higher lag becuase we can launch at much higher rpms than the FWD boys. Also, we won't have to worry about wheelspin when the boost comes on. Go tell that guy to go read a book.
1998 Eclipse GSX (Sold)
Act 2600, Apexi 3" downpipe, 3" exhaust, Hks 3"-5" muffler, Greddy TypeS BOV, Autometer Boost/Vac & Air fuel Gauge, Garrett T3/T4 60-1 turbo (Only boosting 15 psi) Tial 38mm Wastegate, Spearco FMIC, Greedy Profec B2, HKS Turbo Timer Type, Dejon Intake/K&N Air Filter, DSMLink, Eprom ECU, 950cc Fuel Injectors, Walbro 255 HP Fuel Pump, Aeromotive FPR, Drilled/Slotted Rotors, B&M Short Shifter
Old 11-10-2004, 08:21 PM
kjewer1 kjewer1 is offline
AF - Advisor
And let me add that you can't even measure the difference between the two turbos, spool or performance. Everyone thinks that because the big 16g is bigger than the small it will lag more. Do these poeple realize how SMALL the difference between them is? They have the same turbine wheel and housing too! LMAO. Ah well.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-10-2004, 08:32 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
if they have the same wheel and the same housing then whats different between them? and is the evo 16g the same also?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-10-2004, 08:35 PM
Savior1974's Avatar
Kev, check your pm's
AF - Advisor
The big and small 16g have slightly different compressor wheels. Same housings all around, same center. There are poeple running small 16g just as fast as large 16gs. Very minor difference. I also havent seen an appreciable difference between them in airflow, measured on my car.
The EVO16g is different. SBR has a nice page that lists all the differences. But the wheel is better (and airflow is ~5 lbs higher), the turbine housing has some improvements, still the same wheel though as far as I know. I think the small and big are parctically the sam thing, while the evo3 is a clear improvement.
Kevin Jewer
Old 11-11-2004, 05:03 PM
Talon69's Avatar
great thx guys, i kind of figured he was an idiot. lol
