1989 blazer no power to fuel pump
1989 Blazer, there is no power to the fuel pump, changed out relay, ck'd for wires, fuses, and grounds, changed out pump, should be an engine mounted fuse box, left side or firewall mounted, could not locate any suggestions?
Re: 1989 blazer no power to fuel pump
How do you know it is not getting power to the pump, did you testing the wiring for breaks?
1995 Factory Blazer Service Manual for sale, PM if interested. |
as you can see from my original post, changed out relay, ck'd wires, fuses and grounds, now cking the ground to the relay, told that is common problem
So you resistance traced the wires going back to the fuel pump?
Was there infinite resistance?
