Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-10-2004, 04:06 PM
astrix151 astrix151 is offline
very low fuel economy after timingbelt change
Hi,
I had recently changed timingbelt of civic 97. After some 10000 miles, average of the car has went down from 30 Mpg to 20 Mpg.
Does timingbelt have anything to do with it?
What do I need to get done on car's engine to get average high again?
Thank you.
Old 11-10-2004, 04:37 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: very low fuel economy after timingbelt change
have you noticed any other problems with your car besides the bad gas mileage?
Empty Pockets Racing Member #1
Old 11-10-2004, 05:35 PM
There are other problems such as no acceleration at sometimes especially during city driving. Car just stays at same speed and does not pick any speed. And steering vibrations at 60+ Mph.
Thanks for reply.
Old 11-10-2004, 06:29 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Your timing could be off; you could have put the belt on wrong. If you don't line the teeth up right and you put the belt on wrong, the timing will be off. One of the big results of a belt installed wrong like this is....lack of acceleration and pick up, amoung other things I am willing to bet you didn't line the belt teeth up properly when you installed it. As I said, if you mis-algined it and instaled it even 1 tooth off, lack of acceleration and other bad things occur due to the wrong timing.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 11-11-2004, 01:32 PM
Does it mean I have to open everything up again to fix it?
Any possible considerable damage to engine that I need to be looking at.
Thank you.
Old 11-11-2004, 02:02 PM
Honda God
Thank you.
If the timing belt is off like suspected, then you'll have to take it off and put it on so the timing marks are all lined up correctly, etc. Basically slip it off and re-install it the correct way.
EPR Member 4 Life
Old 11-12-2004, 04:59 AM
keifhomeless keifhomeless is offline
yup
ya thats it..same thing happend to me,i especially noticed the power loss from 2nd to 3rd....got the belt adjusted and it ran fine....
