Old 11-10-2004, 03:34 PM
Rolm's Avatar
Rolm Rolm is offline
Where is ecu or computer located 99 Intrigue
Where is the ecu or computer located in a 99 Intrigue I looke in the engine compartment and I could not find the sucker.
Old 11-10-2004, 04:23 PM
paulkramer paulkramer is offline
I think they are all (every year) located underneath the air filter box.....I know for sure that's where they are on a '98 3.8.
Old 11-10-2004, 04:46 PM
Rolm's Avatar
Re: Where is ecu or computer located 99 Intrigue
Thanks I will take a look there. I just hope it's not a bare to remove the airbox. I found replacing the spark plugs a bear especialy when I had to run out and buy an oxgen socket I had to remove the oxgen sensor to remove one of the plugs.
Old 11-11-2004, 09:40 AM
Rolm's Avatar
I did find the ECU hats off to GM they did use their heads on the location. Next question I did install the new/old ecu I picked-up from the bone yard, It did not work It did come out of a 99 intrigue but the engine was pulled out of the car I assumed that all 99's came with 3.8 engines Yes/No ( I was going to keep it as a spare I figure for the cost of $30 why not.
Old 11-11-2004, 11:16 AM
dwalmop dwalmop is offline
No, not all 99's came with 3.8 engines, some came with a 24-valve 3.5L.
Old 11-11-2004, 09:58 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Check the 8th letter of the VIN. A 3.5L "shortstar" will be an "H" motor.
Old 11-12-2004, 06:31 AM
Rolm's Avatar
Re: Re: Where is ecu or computer located 99 Intrigue
I took the unit back for a credit. I just thought I would keep it as a spare. It must of come out of a 3.5L
