Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-10-2004, 04:33 PM
95geser 95geser is offline
type r pistons with gsr
hey i would like to no if putting in the itr pistons in my gsr if they would make a diffrence in power not just reliability. does any one in here have them on theres and can give me some advice. thanks
Old 11-10-2004, 05:34 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
right now ur compression ratio is about 10.0:1, with the type R pistons ur CR will be about 10.8:1
check this website out http://www.c-speedracing.com/howto/c...c/compcalc.php
u wont see too much gains but there will be some gains. not really worth the money IMO. get soem higher compression pistons like the JDM civic type R (P30 pistons) which will up ur compression to 11.5:1
www.MEDIUMRACING.com
Old 11-11-2004, 11:17 AM
b18ls's Avatar
b18ls b18ls is offline
Banned
Re: type r pistons with gsr
CTR pistons... yeah!
Old 11-11-2004, 05:49 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Actually the CTR pistons will bump him to 12.3:1 CR.
Old 11-11-2004, 11:42 PM
gsr916 gsr916 is offline
Banned
Send a message via AIM to gsr916
the CTR pistons would not put him at 12.3:1!!!! he would need racing fuel if it did. that is over the amount of compression pump fuel can take! CTR pistons are put on GSR's quite often w/ no detonation. It would be less than stock CTR compression, so 11:1 or less.
Old 11-12-2004, 12:07 AM
whtteg's Avatar
Re: Re: type r pistons with gsr
Nope sorry buddy but it would be in the 12.3:1 range. The B16B motor has a larger combustion chamber than the B18C1. Therefore the B16B pistons will bump him into the 12.3:1 range. It is true and accurate. You have it backwards, if you put stock B18C1 pistons in a B16B then they would bump the C/R higher than they would in the B18C1.
Old 11-12-2004, 12:54 AM
95dxcivic's Avatar
95dxcivic 95dxcivic is offline
Re: Re: Re: type r pistons with gsr
Your wrong, if the b16b has a larger combustion chamber than the b18c1, then that means the compression is lower in the b16b, compression ratio is the volume of the combustion chamber volume at bdc(bottom dead center) divided by the volume of the combustion chamber volume at tdc(top dead center), therefore if the combustion chamber is larger then the compression ratio is lower.
P.S. You are right that the ctr engine has higher compression ratio, but not because it has a larger combustion chamber.
The type-r engines are made for N/A therefore they have higher comp ratio's than other honda engines.
lowered on photoshop(its not that low, its not lowered at all!)
Empty Pockets Racing Member #4
Old 11-12-2004, 02:07 AM
Banned
12.3 just seems too high. i looked online and a lot of sites say 12.3, some say 12.1... i guess it makes sense but seems like with a cr that high seems stupid to put them in a b18 for a daily driver... detonation is like synonomous with the grim reaper. o well whatever i was wrong, admitted...
Old 11-12-2004, 10:12 AM
b18ls's Avatar
Banned
From my understanding, a CR of 12.3 on 93 octaine is still good. Please correct me if I'm wrong.
Old 11-12-2004, 10:41 AM
Banned
if it is... thats freakin pushin it. that would be like where detonation draws the line
Old 11-12-2004, 11:01 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
According to boostedk20's calculator a stock b18c with b16b pistons yeilds a c/r of 12.042422511586594.
hopefully its not too high for everyday use as its just about what i'll be running once i get my build done.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 11-12-2004, 11:31 AM
kornflakes28546's Avatar
kornflakes28546 kornflakes28546 is offline
i've seen these "JDM CTR pistons" on ebay for like $200. That seems insanely low price. I plan on getting some in the near future and I dont know if i should chance it. what would you guys do? http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old 11-12-2004, 01:35 PM
b18ls's Avatar
Banned
If it comes with rings and wrist pins, it's a good deal. You can get the Spoon balanced CTR pistons for about $125 more. It's not a great deal, but it's not bad either. If you get them and don't like them, I'll probly buy them off you.
Old 11-12-2004, 03:23 PM
Banned
i bet they dont come with rings or pins
Old 11-12-2004, 04:30 PM
whtteg's Avatar
Re: Re: Re: Re: type r pistons with gsr
Originally Posted by 95dxcivic
Quote: <HR SIZE=1>Originally Posted by whtteg
Nope sorry buddy but it would be in the 12.3:1 range. The B16B motor has a larger combustion chamber than the B18C1. Therefore the B16B pistons will bump him into the 12.3:1 range. It is true and accurate. You have it backwards, if you put stock B18C1 pistons in a B16B then they would bump the C/R higher than they would in the B18C1. <HR SIZE=1>
I meant to put it the other way, that was a typo and an error on my part of not proof reading. I am right about the C/R being higher than 11.1:1 in the GSR with B16B pistons. What I meant to say was that if you put the stock GSR pistons in a B16B the C/R will be lower than what it was in the GSR. Its the part in read that I just typed backwards, I was in a hurry LOL. But I am well aware of how c/r is calculated, static and dynamic.
