Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-10-2004, 10:56 AM
slumpbusta88 slumpbusta88 is offline
Post changing fuel pump in a 96 cutlass supreme
Can anyone tell me how to change a fuel pump in a 96 cutlass supreme 3.1L V6?
Old 11-10-2004, 10:58 AM
dwalmop dwalmop is offline
Re: changing fuel pump in a 96 cutlass supreme
it is located in the gas tank, and you need to drop the tank to get at it. First, relieve the fuel pressure if that hasn't been done from a failing fuel pump already, then just drop the tank and go to town.
Old 11-10-2004, 12:46 PM
How hard/easy is it to drop the gas tank?
Old 11-10-2004, 01:23 PM
dhspring dhspring is offline
I had 2 guys change teh pump in a 94 Cutlass, it's kind of a pain in the ass, you really need to be mechanically inclinded or you're in for a long afternoon. You need the car jacked up or on a lift and then you have to lower the tank softly on a jack or by other means, you need the tank as empty as possible, there are several lines to disconnect, but once you get the tank off it's not too bad. you won't be able to do this alone. It's a fair sized job for a decent mechanic, but it'll cost you $500-800 in the shop probably.
