Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 11-10-2004, 10:18 AM
gtmud gtmud is offline
PS hub bracket
Looking for the bracket that the hub bearing and the brake caliper mount to. Can I swap this out with one from a XJ with ABS or is this a GC specific item.
Old 11-11-2004, 10:06 PM
xj31 xj31 is offline
Re: PS hub bracket
You're talking about the knuckle,right? Anything but a WJ should fit
Old 11-11-2004, 10:19 PM
Dale Aeppli Dale Aeppli is offline
Re: Re: PS hub bracket
i think he means the the rotor shield thats the steel round plate the caliper and the hub assembly bolts to they should be interchangable
dale
Old 11-14-2004, 09:25 PM
Re: PS hub bracket
Yes, I'm talking about the knuckle. Its the part that the caliper, tie-rods,ball jionts all bolt to. Oh and the Hub bearing too. So I can get one off of an XJ as long as its ABS?
Old 11-14-2004, 09:26 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: PS hub bracket
well then a steering knuckle from any ZJ should fit, and one from an XJ should fit as well
Old 11-14-2004, 11:24 PM
Re: PS hub bracket
the xj part will be fine.Doesn't matter about abs unless its the axle shaft.The tone ring is on the outer end of the axle.
Old 11-17-2004, 01:13 PM
Re: PS hub bracket
Found a cheaper fix, found the M8x1.25 Hela coil kit at ADvance Auto, so tonight I will finish this project.
