Old 11-10-2004, 09:49 AM
eorozco3 eorozco3 is offline
Angry SRS light on and horn won´t work
The air bag light came on after I changed the rack and pinion on my 94 Civic, and also the horn won't work, I'm about to reset the yellow plug under the dash, but before doing it, I wanted to know if anyone knows what could have happened, I didn't mess with any conectors when I changed the rack and pinion, anyone with an answer?
Molto Gradche.
Old 11-10-2004, 09:56 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: SRS light on and horn won´t work
From the sound of it, u did something to the connectors that go from the steering wheel to the ecu. So now the Ecu is thinking your SRS is not working. But im not completly sure becausei wasnt there to see what u did. Wheres jackasssi when u need him?? lol good luck
Old 11-10-2004, 10:48 AM
All the work I did was under the car, removed the screws that hold the steering column to the rack and pinion, it kind of drop a litle, kept it in place, remove the rack and pinion, install the new one, put the column back, screws and done! What could have disconnected inside the steering wheel?
Old 11-10-2004, 10:53 AM
polacek's Avatar
polacek polacek is offline
There are a bunch of connections with the steering column, including the SRS. Try them all. Could be that the all look seated in the connectors, when in fact one might be a little loose. Did you have the battery connected when you did the work? If so you might have blown a fuse somehow. Also, if you didn't disconnect the power cable from the battery, it is very dangerous to do any work on the car, especially within the engine compartment. good luck
Old 11-12-2004, 01:20 PM
Found the problem, there is a round connector in the steering wheel where the cables for the airbag and horn are attached, under the airbag, it was broken, I had to tear apart the whole thing to find that out, just in case someone else has the same problem in the future.
Old 11-12-2004, 07:06 PM
polacek's Avatar
Thank you for the update and information
