Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 11-10-2004, 08:44 AM
VINCENT007 VINCENT007 is offline
Question New Tire Problem
Hi Guys. Just Got 2 New Front Tires On My 2001 And The Low Tire Pressure Light Keeeps Coming On. I Checked The Pressure And It's Ok. What Could It Be? Is The Sears Auto Shop That Put Them On Responsible Or Is There Some Specail Way To Reset After New Tires Are Installed. Any Help Would Be Greatly Appreciated................
Old 11-10-2004, 09:21 AM
dred98's Avatar
dred98 dred98 is offline
Re: New Tire Problem
Are they the same size as the originals? A lower profile might confuse the computer.
Dark Red '98 - Autobahn - Airbox Mod - Sunroof - Cool Blues
http://www.howardm.net/dred98/aurora.php
Old 11-10-2004, 09:25 AM
Nope. Same Size Tires.
Old 11-10-2004, 11:03 AM
dred98's Avatar
I don't know where it is, but there's a sensor that reads the rolling speed of the wheels and reports back to the computer, it must be screwed up or disconnected somehow. You need someone with a 2001 factory service manual to tell you where to look.
Old 11-10-2004, 11:24 AM
Thanx A Bunch
Old 11-10-2004, 02:34 PM
protek22 protek22 is offline
Re: Re: New Tire Problem
Originally Posted by VINCENT007
Thanx A Bunch
Vincent007,
You must check each new tire's pressure upon installation, if correct, you need to reset the tire pressure section of your DIC display. This has to be done whenever you change tires.
Old 11-12-2004, 11:20 AM
apostolakisl apostolakisl is offline
This is normal after replacing the tires and needs to be reset. To do this, scroll through your computer menu to the gauges section and then to the section for tire pressure. It should say "low pressure". Push and hold the reset for about 5 seconds. This is the same procedure you go through to reset the oil pressure. If you just hit the reset button when the warning screen goes up, the computer does not actually reset, it only clears the screen of the warning until next time you start the engine.
Old 11-12-2004, 11:25 AM
Thanks. It Worked. Awesome.
