Old 11-10-2004, 02:12 AM
bighead bighead is offline
Add Coolant light stays on
I know what it means... Add coolant.. But, the res. tank is full. Any ideas...I just put everything back together tonight (See posting: White Smoke) Did I miss something or do something wrong?
The bleed valve on the metal tube in front...Does that need to be closed or leave it open? I filled it full of water/coolant and it started dribbling out of it.
Also, My temp guage stays around 3/4 before the fan kicks on. Is there any way to make it come on sooner?
Old 11-10-2004, 07:13 AM
dwalmop dwalmop is offline
Re: Add Coolant light stays on
the bleeder valve needs to stay closed, which brings me to my next question: Did you properly bleed the coolant system? There could be an air bubble trapped around the sensor. When you fill the car back up with antifreeze, make sure the bleeders are open, then close them when you install the radiator cap and start it.
Old 11-10-2004, 11:20 AM
Where is the sensor for this type/year of car?
Old 11-10-2004, 11:27 AM
Not positive, but it think it should be somewhere on the radiator
Old 11-10-2004, 12:42 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
or near the thermostat…
Old 11-10-2004, 02:03 PM
Did a flush and fill, followed the directions... same thing..
Old 11-10-2004, 03:36 PM
Langning Langning is offline
The sensor is at the coolant reservoir tank bottom (for my 96 Cav LS). I had had the same problem and was told to tap the sensor area with a screw driver (use the head to tap). After numerous (light) taps and my light stayed on. Then I was told to hit it harder; and I did and the light went off...
Old 11-10-2004, 05:34 PM
No worries...I think it was just an air bubble...After the flush and fill, I drove it for 3 miles or so... Light went out. DONE...FINISHED...
Old 11-15-2004, 02:19 PM
Okay..it is back...seems to come on after a few minutes of stop and go driving. My temp stays within the normal operating range. Any Ideas?
Old 11-15-2004, 06:02 PM
KJRich's Avatar
KJRich KJRich is offline
Send a message via AIM to KJRich Send a message via Yahoo to KJRich
Re: Re: Add Coolant light stays on
Sounds like the sensor. I've heard it goes bad frequently. Should be somewhere on bottom of reservoir, like Lanning said.
1999 Chevy Venture LS Extended 3.4 V6 Intake Gaskets Replaced
2003 Cavalier LS Sport Coupe, 2.2 Eco, 5 speed Getrag, all black
Old 11-15-2004, 07:51 PM
Yeah.... I put a new sensor in...Light stayed on...Hit the hell out of it with the palm of my hand..Light went out.. We'll see how things go....
