Old 11-10-2004, 01:21 AM
Mouse96 Mouse96 is offline
Left rear signal
I sure hope someone can help me. I have a 96 Cavalier. The left brake light / turn signal is out. I replaced the bulb, and it still didn't work. Suddenly it was working, was fine for a few days, then quit again. Then it worked and then it quit. That's where I am with it now. The front signal blinks, but it blinks rapidly now. I assume to let me know that the rear one is out. (??) All of my other lighting is fine.
Could this be the wiring?
I saw some wires when I pulled the carpet down to replace the bulb. Could I have loosened a wire or two? And...If something is loose, how will I know. I am not very car savvy at all. And my husband is worse.
BTW, the wires I saw in there just had electrical tape and wire nuts on them. Is that how it normally is?
Thanks!! Mouse96
Old 11-10-2004, 02:42 AM
big dude1 big dude1 is offline
before you go tearing out ure wiring check to see if the socket is bad... on my 83 cougar the lights would work for a while then stop... what happened was that metal tab thing that the bulb contacts was pushed all the way in so it only contacted the bulb part of the time... so check if its the socket before you check all the wires...
i love my new sound system... Alpine type R 12" sub, Alpine deck, and MTX amp
2001 Z24 cavi, and it owns
Old 11-10-2004, 08:13 AM
You just reminded me... When I changed the bulb there was this weird crust in the socket. It looked like dried up wood filler or tan putty. I scraped a lot of it out but not all of it. What could cause a funky build up like that in a tail light socket??
Old 11-13-2004, 05:47 PM
ttweakk27 ttweakk27 is offline
Send a message via Yahoo to ttweakk27
Re: Left rear signal
The factory puts it on the to prevent corrosion. its called bulb grease. its really messy stuff, but its keeps the corroion away.
Old 11-13-2004, 06:30 PM
lol i dont have any gunk in my sockets and i dont have corroded sockets either... just see if scraping the gunk out might help... ? u never know with cars these days...
Old 11-14-2004, 01:36 AM
brucedana's Avatar
brucedana brucedana is offline
It sounds like a bad ground wire.But what I would do is check all your bulbs.Front and Rear.Sometimes one bad bulb can cause this problem.Does that putty look like peanutbutter? If so thats what the factory puts in the socket to keep water out of the conection.
Old 11-14-2004, 07:14 AM
Hi Guys.. Thanks for the responses so far. I posted a different thread, but I can try it here too.
I pulled the bulb out of the socket, looked it over and found the problem.. The socket melted the metal conductor strip into the plastic base of the bulb. I replaced the bulb and it's working for now, but I know I need to get a new socket. How the hell do I go about taking out an old one and putting a new one in??!!
Anyway, Thanks again. Mouse
Old 01-11-2005, 01:24 PM
Cava_Z Cava_Z is offline
I had the exact same problem and it was a bad socket, the only solution is to replace the bulb socket. It's very easy, it takes about 3 min. to change. All you have to do is unplug the the socket from wire and plug in a new one, in my case I just went to a pull it yourself yard and got one and I haven't had a problem since (a year ago).
Old 01-11-2005, 01:36 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
holy shit back from the dead batman..lol...
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-11-2005, 08:26 PM
gonzales7727's Avatar
gonzales7727 gonzales7727 is offline
Go to the dealer, cost ya about $10.00, comes with the pea light already on it and it will take about thirty seconds to change the whole thing out, theres a quick disconnect on the back of the harness.
