Old 11-10-2004, 01:14 AM
sheng sheng is offline
Send a message via AIM to sheng Send a message via Yahoo to sheng
what you guys sugest, getting more power from my B16A vtec, besides I/H/E,???
what more can i do???? besides camgears an I/H/E??
Old 11-10-2004, 01:31 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: what you guys sugest, getting more power from my B16A vtec, besides I/H/E,???
Depends on the $ you're willing to spend. If you've a few grand to burn you could get a turbo kit. Or you could get some cams and/or higher compression pistons.
Old 11-10-2004, 03:06 AM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
TONS!!!
You could get cam sprockets, new rods, better fuel filters, fuel rail, FPR (fuel pressure regulator), new ground kit(cheap if done yourself), new ignition system, get yourself some new pistons, pulleys, new camshaft, valve springs and retainers, spark plugs and wires, bigger throttle body. Go a little more crazy and through in a different ECU, or a stroker kit, cant forget a V-AFC, or like was previously mentioned, go turbo. Or you could toss in some NAWWWWWWSSSSSSSSS. Its really up to you man, all depends on how far you wanna go, and how much you wanna empty your wallet.
Official AF Primer Crew!
Updated 1-23-05
For sale: Stock 4-door corner lights. 13" stock wheels with 6 month old tires.
Old 11-10-2004, 07:51 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
yea, that stuff gets reallyyyy expensive, but turbo is nice
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 11-10-2004, 08:31 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
the stock fuel rail is capable of 400 BHP so its not worth changing that unless you have money to burn
i would go for some CTR pistons, cams and valves, then maybe the type R T/B too
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 11-10-2004, 08:34 AM
clawhammer's Avatar
clawhammer clawhammer is offline
^When you do a swap from D16 to B16, do you usually replace the fuel rail as well? I was thinking of getting a high flow fuel pump, and I have a D16, is that still going to be sufficient?
Old 11-10-2004, 08:36 AM
Civic Jim's Avatar
you will have to change the whole inlet manifold mate, the engine wont fit onto to anything D series, i think the fuel pump is ok though ?
B16A1 I/H/E
4TH GEN UK SITE
