Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-10-2004, 12:25 AM
alexortiz82 alexortiz82 is offline
Angry trunk lock busted and disgusted
Some low life recently broke into my Chevy and took my stereo system.They broke the trunk lock and I was wondering if there is a way to get rid of the lock mechanism all together and possibly bondo the hole. I assume the only means to open the trunck would be through the glove compartment box switch. How do I go about making this cosmetic change to my violated Chevy?
Old 11-10-2004, 05:48 AM
CD Smalley CD Smalley is offline
Re: trunk lock busted and disgusted
Grind the paint off around the area.
Cut a small piece of sheet metal to fit into the hole.
Weld it in place with a series of tack welds until all the gaps are filled.
grind it smooth.
repeat welding steps if need to fill hole.
grind it again.
skim layer of bondo.
sand and paint.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 11-10-2004, 12:43 PM
Thumbs up
Thanks for the info. I plan to start working on the car as soon as this weekend.
Old 11-10-2004, 07:59 PM
TommySS TommySS is offline
You may want to rig up an emergency release cable on the off chance the switch, wiring, or release motor quits.
Doesn't have to be elaborate, in fact, it should be pretty easy.
Old 11-10-2004, 08:24 PM
Good idea there Tommy. The guys with the shaved door handles and poppers do that too. I forgot about.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 11-10-2004, 10:04 PM
Thanks for the great ideas guys. Any suggestions as to how to rig up a plan B in case the trunk wont open from the interior?
Old 11-11-2004, 05:46 AM
Well the guys with the shaved door handles, just use a piece of small diameter stainless steel cable. They run it through the door with the wiring and out to a place under the fender. I guess I would do the same but keep it hidden behind the license place frame....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 11-11-2004, 11:59 AM
Thumbs up
Good looking out. I really apreciate the help and excellent suggestions I have received in this forum. Thanks guys
