Strong Vibration at Steady Speeds
I have a 95 firebird with a strange problem.
When i get into 3rd gear the car mostly the rear vibrates badly at 1600-2000rpm if i accelerate it stops but i cant keep a steady speed from 45-60. I half to accelerate and just take my foot of the gas or the car felas like the backs going to fall off. Any ideas what could be causeing this? |
Re: Strong Vibration at Steady Speeds
Does it shake in first and second gear at the same RPM? Does the shaking stop as soon as you apply more throttle, or after you pass the 2000 RPM mark? |
check to see that the drive shaft is properly balanced. Since it's easier, though, bring the rear tires to a shop and have them road-force test them to make sure they're not out of round, if that doesn't clear it up, I'll be it's your driveshaft you're feeling.
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
Re: Re: Strong Vibration at Steady Speeds
Im not sure wat mantance was done before it started it was a long time ago it was my roomates car. Talking with some people at work one had the idea of rear universal joint. Could it be going or gone bad? |
Re: Re: Re: Strong Vibration at Steady Speeds
I agree with Dwalmop, do the cheapest things first. You could save some money by swapping the front and rear tires yourself and retesting for a change in vibrations. Then I also would look at the driveshaft. If you go into a garage to have them look at the tires, maybe you can sneak a quick look at the rear undercarriage to see if anything is loose. Or if the tires are OK, ask them to take a quick look while it is on the lift. If all OK, change the rear U-Joint. Then the front U-Joint. |
Wouldnt the driveshaft cause vibration nomatter what speed i went? Not just dureing steady speed 45+?
A damaged driveshaft could do either. If one of the weights or something fell off it could cause vibration at a certain speed or if it had more serious damage or a damaged U-joint it could cause a varaition at any rpm range. From the way your describing it though I would tend to agree with Hypsi that it would most likely be a bushing. Good luck and keep us posted. Also welcome to the Forum.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) Last edited by FormulaLT1; 11-12-2004 at 08:26 PM. |
Thx I will keep all of you posted.
Im planing to take it into a shop next week. Till i get it fixed i can just use my unkillable 1980 monte carlo. Looks like crap but it not going to die any time soon. Here is some of the things im going to have looked at when i take it in. TuneUp-Since i dont know when last one was done. Replace driverside window motor-Its dead Check Engine Mounts-Just so i feal beter New Drive Belt- current one just looks a bit warn just make me feal better. Radiator Flush-I noticed alot of crud built up when i checked it. If you have any sugestions on things i should have looked at. i welcome any sugestions. |
Bushings!!!!!
Yes, if the vibration occures at the same engine speed reguardless of which gear the transmission is in, the driveshaft shouldn't be the issue.
Since you said it only occurs in third then you may have a faulty driveshaft since the speed of the driveshaft varies in different gears at the same rpm. I would do a visual check of your driveshaft and make sure there isn't any built up dirt or any type of foreign undercoating on it that can affect the balance. If you see any dents in the in then I would definately get it checked out. Missing weights could also cause the vibration. Worn u-joints bearings is also a possibility. |
