Old 11-09-2004, 10:21 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
95 blazer front end
1995 4dr 4wd blazer. i just replaced lower, upper balljoints on both sides, inner and outter tie rods on both sides. now my car has started to CREEK quite loudly. usually when i turn left going down a hill, when my right side of the car goes down. but it sometimes happnes when i turn right as well. just more when i make a left. suggestions??
Old 11-10-2004, 10:38 AM
JoulesWinfield's Avatar
JoulesWinfield JoulesWinfield is offline
Re: 95 blazer front end
Yes, I have a suggestion.
Take a look at your Idler arm. I would bet you a dollar that it has a straight zerk fitting, and therefore no one has ever greased it, or even bothered to tell you that your Idler arm has been completly dry for years.
Seriously though, take the plastic splash pan off and take a look at the Idler arm, its on the right side of the vehicle (always from the driver seat). If you can, have someone turn the wheel while you watch and listen. You will most likely find what I described.
Old 11-10-2004, 08:54 PM
i will try that tomorrow since there is no daylight left. i will post a reply on what happens. thanks
Old 11-10-2004, 09:07 PM
dwalmop dwalmop is offline
I can't tell you how many idler's I've replaced on blazers, jimmy's bravada's, etc. Nobody lubes them and they become toast fast. Whoever replaced everything else should have caught that though
Old 11-11-2004, 01:51 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
This has got to be the front sway bar bushings and end links. It happens when it drops one side when not turning so that takes the idler arm out of the equation.
Dry sway bar bushings can cause the squeak.
But for the hell of it, I would lube all 11 grease fitting on your front end to maintain it properly.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-11-2004, 09:57 AM
all 11? list would be appreciated. thanks in advance
Old 11-11-2004, 10:05 AM
Mikado14 Mikado14 is offline
Ask and you shall recieve:
Left upper ball joint
Left lower ball joint
Inner tie rod end
Outer tie rod end
Right upper ball joint
Right lower ball joint
Inner tie rod end
Outer tie rod end
Idler arm (2)
Pittman
This is on my '93, yours shouldn't be much different. However, I have found on a '95 upon replacing ball joints, that GM didn't have zerks in the ball joints but by now, I'm sure someone has installed them at some point.
Old 11-11-2004, 02:05 PM
i just replaced all four ball joints about 2 weeks ago. ill greese them all again though. thanks
Old 11-11-2004, 07:57 PM
BlazerLT's Avatar
AF -Advisor
don't force too much grease in there, just maybe a pump will do it.
I have a 1995 and have all 11 and they are factory with the zerks.
Too many people are not EVER lubing their front ends on these blazers.
If they took the hour to do them all, the components will last 5 years longer.
Most of the failures are from lack of proper greasing and maintanence.
