Old 11-09-2004, 08:33 PM
JStin JStin is offline
Any '92 PA balljoint replacement ponters?
Due to a shimy in the front end I'm planning on replacing both balljoints on my '92 PA. Anybody have experience with this job? I have the Haynes manual, but I've never done any front end parts before.
Any special tools, prep work, etc. needed. How long should this mission take?
Thanks
JStin
Old 11-09-2004, 09:01 PM
vljenewein's Avatar
vljenewein vljenewein is offline
Banned
Send a message via ICQ to vljenewein
My suggestion is to take it to a repair garage that also does front end alignment. They will align the front end and install the ball joints. Probably will definitely need the alignment even if you did it in your garage, and you will save yourself a lot of headaches.
my 2 cents worth.
Old 11-10-2004, 11:53 AM
parkavenuechrome parkavenuechrome is offline
Re: Any '92 PA balljoint replacement ponters?
my 2 cents worth.
You will need the aligment done regardless, but change the ball joints yourself.. save yourself 90 dollars a side in labor. now is the time to replace the struts too. the allignment will have to be done again with strut replacement. do it all at once. you'll be glad you did.
