My car is 98 camry LE. It has no problem at all when I drive it locally. Last time, after I drove at a speed of 75mph on highway for about 5 minutes, the engine became shaking greatly when I was waiting for the traffic light. The engine speed jumped back and forth between 0 and 1000rpm. After a while the engine went dead. I strated it, same situation. After several minutes, I started it again. It became normal. I drove back at a lower speed. I had met this situation before. I asked the dealer to check the problem. They told me to replace spark plugs. I did it two months ago, but it seems that did not solve this problem. I am guessing something wrong with my EGR system. Could anyone give me some advice? I really appreciate your help.
Re: Engine shaking, Please help
Do you have a check engine light? If there is no check engine light, then probably it is not the EGR system. |
Re: Re: Engine shaking, Please help
Sometimes if the TPS sensor is going bad it will do the idle hunting as you mentioned.. usually there is a code for that as well. I would check the air filter, change the fuel filter and perform diagnotics per the manual to verify the TPS sensor is performing correctly. |
The check engine light was on, and I checked. There is no code. I think the check engine light will automatically be on when the engine idle speed is pretty low.
Re: Re: Re: Engine shaking, Please help
Thanks for you help. I will check the EGR valve leak first by using your way.
Re: Re: Re: Re: Engine shaking, Please help
