Old 11-09-2004, 07:03 PM
wesydde wesydde is offline
Angry rear wheel bearings
Help! Last year had Both rear wheel bearings replaced. lasted for a approx 3 months then took back and had redone.
About 2 months ago same problem, terrible loud noise again appeared.
Took to local shop replaced both sides (rear wheel bearings)
Lasted maybe one month started making that horrible sound again.
The last week replaced AGAIN. They said the spindles are ok.
Sooooooooooooo what in the @#$% is going on. Any suggestions.
I am out of $$$
They cant figure it out
I have a 2 door 1995 Geo Metro
HELP
Old 11-09-2004, 11:09 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: rear wheel bearings
sounds like something is bent or warped. i would go get a used drum with bearings at a wrecking yard, shouldn't be more than $20 a side with the bearings, just slap them on with the new drum and see how they work. also the take a high temp grease, maybe shops aren't using right grease
Old 11-10-2004, 06:01 PM
Zogboy Zogboy is offline
It may be that your drums are rusted and rubing the backing plate. That makes a hell of a noise.
I had the same on mine and though bearings, but they looked great so I repacked them.
I really don't see how those bearing could go bad if you keep them well greased.
Old 11-12-2004, 07:29 AM
crazyinkc crazyinkc is offline
My 95 had bad bearings in the left rear when I bought it. I went to the junk yard (U-Wrench-It) and pulled 2 drums with bearings for $11 each. I do not know why you keep having bearing trouble but I would suspect lack of proper lubrication. Make sure they are using a high temp grease and not a chassis grease. They my not even be greasing them at all. Look to see if the bearings are rusty.
Old 11-15-2004, 04:55 PM
geozukigti geozukigti is offline
Been there, done that, had a bent rim....
Old 11-19-2004, 10:01 PM
rusmel rusmel is offline
I went through a lot of rear bearings on my '94 Metro. The Chilton's manual had two very different torque specifications for the rear axle nut in different locations in the manual. I no longer have the car or manual, but it was something like 200 N-m (146 ft-lbs) compared with 70 N-m. When I used the higher spec I didn't seem to have the problems. Note that garages will regularly remove the nut to check the brakes and just reinstall the same nut (the manuals recommend that the keyed nut be replaced each time) to the previous keyed position (approximately) without checking the torque.
The bearings cost very little, but it's a pain to have to keep replacing them.
