Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 02-23-2002, 02:26 PM
Cav Cav is offline
Moisture In My Head Light
I noticed some moisture in my left front headlight on my 88 CRX, can anyone give me some directons on how to remove the water and stop this from happening?
Thanks
Old 02-23-2002, 03:13 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Moisture In My Head Light
Thanks
Well obviously theres a leak. I have the same problem. I wouldn't try to do anything to it. Just buy a set of new headlights that doesn't have leaks. Otherwise u have to open it up. I heard its a pain in the ass to do.
Old 02-23-2002, 03:26 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Yeah, just buy new headlight(s). I had the same problem, and I attempted to open the lights.....they broke.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 02-23-2002, 10:04 PM
Cav Cav is offline
will keeping the water in the headlight cause any serious problems later on?
thanks
Old 02-23-2002, 10:14 PM
kris's Avatar
kris kris is offline
Off playing with fire.
thanks
I had a leak in my headlights once. Every time it rained, or I went through a car wash, if the lights were on, and hot, the water would make them blow.
Old 02-23-2002, 10:56 PM
SkyNex721's Avatar
SkyNex721 SkyNex721 is offline
Send a message via AIM to SkyNex721
If the water stays in there for awhile, the reflective material will start to crack and diminish. Then your light will appear to be dim.
R.I.P. - You shall be resurrected.
Old 02-24-2002, 02:34 AM
CRX_FANATIC CRX_FANATIC is offline
Yeah the water will rust the inside of the housing and ruin it, so you should just get a new headlight assembly...when you put the new assembly on put some silicon along the seals so that way it doesnt leak again
