Old 11-09-2004, 06:14 PM
Hpnotiq86's Avatar
Hpnotiq86 Hpnotiq86 is offline
Send a message via Yahoo to Hpnotiq86
Anything wrong with Mechanical boost control?
I am going to be needing a boost controller, but dont want to drop $300+ for a good Electronic one. The only reason I dont go electronic now is because I plan on getting DSMlink and Spending $300+ seems pointless if I am getting DSMlink in a a few months. Anyways, can anyone recommend a good boost controller, I was loking at the dejontool ones, but dont know if one is better than the other...
Also, is there a downside to Mechanical Boost Controller, are they accurate and efficient, or are they just inconvinient and hard to use?
Thanks.
Old 11-09-2004, 06:29 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Anything wrong with Mechanical boost control?
turbo SX makes good ones,...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-09-2004, 08:08 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
theyre easier to use but you do have to stop and adjust it outside. dsmlink doesnt have in boost controller in it btw. one advantage of electronic boost controllers is being able to have different setting that you can jump between easily. but they take longer to set up then a mechanical one
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-09-2004, 09:13 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
cheap ebay boost controller. mine works great..
DSM geek
Old 11-09-2004, 09:32 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
www.boostcontroller.com has JoeP and Hallman boost controllers for ~$50.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 11-09-2004, 09:44 PM
kjewer1 kjewer1 is offline
AF - Advisor
Joe P and Halman seem to be best. Turbo XS almost always give excesive spike on 16g and smaller turbos. I used to run a Profec B, which was very convienent, but wouldnt go over 26 psi no matter what I did. The Joe P I use now is fine, just a pain in the ass to get out of the car and adjust. But its been rock solid up to 30 psi so far.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-09-2004, 10:12 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
yea cheap ebay bc same here...i have the same one as scotsee has...only cost me 20 bucks shipped!
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 11-10-2004, 07:57 AM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
Joe P!!!!!!
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
