Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 11-09-2004, 05:51 PM
DodgeDaytonaV6 DodgeDaytonaV6 is offline
Possiblity of AWD or RWD?
Is there a way to convert a 1990 'tona with the 3.0L to a RWD or AWD car? Any info on this would be GREATLY appreciated. Thanks in advance...
Old 11-09-2004, 07:54 PM
dougger222 dougger222 is offline
Re: Possiblity of AWD or RWD?
Back in the day Carroll Shelby did up an all wheel drive Daytona. I've seen in person an all wheel drive Shadow P body with a second motor in the back seat to power the rear wheels. There have been lots of Daytona's converted to rear wheel drive for drag cars with big V8's.
I bet if you took the rear parts off of an all wheel drive Caravan you could possibly rig something up. The conversion will take lots of time and even more $.
If your looking for speed just by a T1, T2, T3 or T4 Daytona and put some mods on it. (T1=146HP, T2=174HP, T3=224HP and T4 is the VNT, variable nozzle turbo which makes 174HP. I think a 3.0 V6 is good for 130HP in stock form.
1999 Ford F250 XLT X-cab short bed 4x4 Powerstroke auto
2000 Ford Excursion Limited 4x4 Powerstroke auto
1989 Shelby CSX-VNT #339 of 500 all original with Recaros
1986 Shelby GLHS #284 of 500 restored to original
1965 Ford Mustang 289 V8 pony interior 4brl carb
Cars sold or parted out in a 3 month period,
2-85 GLHT's, 2-88 Shelby Z's, 87 Shelby Z, 88 Lancer Shelby, 2 85 Shelby Chargers, 89 Shelby Daytona
Old 11-09-2004, 10:11 PM
An engine swap is also a helluva job as well as expensive. Around here, a Daytona is rarely found and those that are, aren't exactly parts cars. The 3.0L is good for around 141 horsies, perhaps around 130 at the wheels. Turbo setup will put it at 260 whp and 270 ft-lb of torque with 9 psi of boost. In total, this engine is capable of 400 hp or more, but thats with a major engine rebuild with several modifications, and even more money... But with the turbo running around $1300 for all the parts (not a kit), its reasonable for an extra 100 hp... These engines have been passed off as weak engines when a little modding can go a long way...
Here you go...http://home.tampabay.rr.com/redroby/3liter/summary.html
1990 Dodge Daytona ES (Parts) | 1993 Dodge Daytona ES (DD/Project Car)
Doing/Done:
4 Wheel Disc Conversion (In progress)| 5 speed manual swap (In progress) | 52 mm Throttle Body | K&N Air Filter
Soon to come:
Underdrive Pulley System | Port & Polish Heads, Intake & Exhaust manifolds, and plenum | 0.040" Venolia Forged Pistons |
3" Catback exhaust (custom mandrel bent) | Custom exhaust manifold and crossover pipe | Garrett TO4E 57 trim | Walbro 255 lph Fuel Pump
Old 11-10-2004, 05:47 PM
119 horses from a turbocharger? That must be some turbo set up!!! Is that a double or triple set up? If I recall a 2.2 NA is good for around 100 HP put a turbo charger on it and you've got 146 HP. 46 HP for a turbo for a 2.2 or 135ci.
That link has a lot of fuzzy numbers. I'm sure after building up a 3.0 with stronger rods and such you could create some HP but 400? That would take a ton of mods and even more money.
I bet there are 10+ guys that build up 2.2 or 2.5 turbo Daytonas to 1 guy building up a 3.0 V6 Daytona.
Old 11-10-2004, 09:04 PM
Talking
No, its not a double or triple, its only a single turbo and its good for up to 300 horsies. And just like you said it, around a 10:1 ratio of 4 cyl to 6 cyl that are modded.... I want this car to be a unique as possible. Everyone and their brother has a 4 cyl turbo Daytona... How many have a turbo V6?
And as far as the rods go, these are the same rods from the famed 3000GT VR4 aka Stealth R/T Turbo. These cars were sitting around 320 hp stock. The entire bottom end is the same . Thats why a set of rods for this thing run in the $1000 range for anything any stronger.
Doing/Done:
Soon to come:
Old 11-14-2004, 01:05 PM
I guess if the lower end can handle the HP may as well mod it to see how it handles it.
What color is your car is it an ES or IROC? A turbo V6 Daytona would be something out of the ordinary!
Old 11-17-2004, 09:11 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
you can also use the drive tran out of a AWD mini van - like the new chrysler town an country - they work very well.... an can take a decent load....
Old 12-01-2004, 10:18 PM
my daytona is a ES model...i'd just like to see what can be done... i have seen many people tell me to just get a 4 cyl and mod it, but i don't wanna do it the easy way... it will be worth it when i can say that i have one of the few turbo charged 3.0L v-6 engines, producing a good 300 hp... ... could you imagine 300 hp with awd in a car that weighs around 3000 lbs? with an upgraded suspension, omg... *creams*
Doing/Done:
Soon to come:
Old 09-09-2005, 09:57 PM
99grandgt's Avatar
99grandgt 99grandgt is offline
Send a message via AIM to 99grandgt Send a message via Yahoo to 99grandgt
alright guy, in the early to mid 90's, a company DID make swap kits including the k member to make a LA block fit the daytona. i did research, and they dont make the kit anymore, so you will have to weld up your own k member to fitthe motor mounts, and crazy enough, a lot of the parts used to hold the extra v8 weight came from none other than that of the mini vans, direct bolt in. you can search on hotrod.com, they had an article in one issue a year ago. i cant find it, its somewhere in my house, just moved, but it has all you need to know on rwd swaps. an awd swap would be easier, any talon or eclipse awd rear axle will do, a custom driveshaft, and the ptu from a van will bolt right into an auto tranny case. not too sure bout the sticks, but im sure it will fit. good luck and have fun
"haze grey and under way!!!"
99 honda odyssey
99 grand prix gt
possibly a g8 gt when i get to cali
Old 07-27-2009, 08:13 PM
exline exline is offline
If anyone is interested we make the RWD conversion parts to V8 a daytona sundance lebaron or shadow.
www.exlinecustomauto.com
