Old 11-09-2004, 05:08 PM
anol anol is offline
How To Roll Fender
i use eclipse 2003 with rims 19 inch but i want to make the rear fender drop inside the tire ,i use teins spring but its still high just 1.7 inch ,i want to cut my spring and make drop until 3 inch thats why i want to roll my back fender or do u have another sugestion?? thx
Old 11-09-2004, 06:07 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: How To Roll Fender
heat the springs with a torch, and stand on the bumper
DSM geek
Old 11-09-2004, 07:12 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
cut/heated and shrunk springs are going to ride like shit. each one you do will turn out different and your car probably wont sit level anymore. even if you can get it to sit level the spring rates will be different. if its a show car its ok but if you want to drive it i wouldnt recommend it
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
