Old 11-09-2004, 04:50 PM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
Why won't my Milliputt dry?
Hey everyone
I just bought some Milliputt, and used it for the first time the other day on my Eclipse that I'm building. I applied it Sunday afternoon, and come Sunday evening, it still wasn't dry. I thought that the humidity of the basment may have had something to do with it, so I brought it upstairs, so that it was sitting in a low humidity, room temperature enviornment...I can still see my finger prints when I push into the putty with a small amount of force. Does anybody have any idea what could be causing this, or how to fix it? The two parts were thouroughly mixed, no streaking, etc., and I continued to mix them for another minute. Any help would be great. Thanks in advance!
-Chuck
Old 11-09-2004, 06:18 PM
g00eY's Avatar
g00eY g00eY is offline
Re: Why won't my Milliputt dry?
you only waited for a few hours? u gotta wait a lot longer.
Old 11-09-2004, 06:29 PM
The box says in "Rock hard in two to three hours"...unless I misread 'days' for 'hours' without my glasses...
-Chuck
Old 11-09-2004, 06:30 PM
SLAYTANIC_1134's Avatar
SLAYTANIC_1134 SLAYTANIC_1134 is offline
I am not particularly familiar w/ "milliput" but if is a two-part putty you want to make sure you mix it evenly; sounds like there is not enough hardener. Also I always let my big putty jobs dry for at least 24 hrs. to allow for shrinkage, curing, etc.
Old 11-09-2004, 06:40 PM
g00eY's Avatar
i dont think you should pay attention to what the box says. yes, you should make sure that you have the same amounts of each part and mix them evenly.
Old 11-10-2004, 11:47 AM
008's Avatar
008 008 is offline
I threw my packaging away but I'm fairly certain it said "Cures in 2 to 3 hours, rock hard in 24 hours". Either way, I don't touch it for at least 2 days.
Old 11-10-2004, 01:25 PM
DukeMan's Avatar
DukeMan DukeMan is offline
I love Milliput, it´s sooooo useful. Anyway, besides blending it more exactly i order to make it hard, just put it under a lamp, that really speeds up the process. And if I may I´d like to give you a tip on how to get a great, smooth surface immidiatly unless you already know this (took me a while to figure it out). Simply use a lot of water, NOT when you apply the putty though, that will only make it slide around. When you have it in place, fill a bowl with water and hold the piece that your working on over the bowl, then just wet a finger and start rubbing on the putty, just like when using abrasives. When you´re good at it, you won´t have to use any abrasives, well at least not until a p2000 to get a shiny surface. But back to the hardening problem, when you´re happy with your "finger-grinding", put a few drops of water on top of the puttied surface and place under a desklamp for 1-2h. after it should be able to polish, if not there´s gotta be something about your blending.
Regards, Fredrik
/Fredrik
Current Projects:
-´70 Camaro Z28 (Baldwin Motion hood wanted!!!)
-´32 Ford Roadster (on hold)
´69 Camaro thread
