Old 11-09-2004, 03:47 PM
blazer31907 blazer31907 is offline
Question problem with a 4.3 CPI
just replace the fuel injector and the return fuel line.still spuddering and blow out black smoke when I step on the gas.then when get down the road the service engine light comes on.code (45) O2 sensor indicates rich so I replace the O2 sensor still nothing.do I need to replace the evaporative charcoal canister or what do I need to do next.would highly appreciated if someone could tell me what it could be.
Old 11-09-2004, 08:54 PM
Fireplug Fireplug is offline
Re: problem with a 4.3 CPI
What year? what engine?? Just because you got a code does not mean that a sensor is bad. The o2 was doing its job by setting the code for rich mixture. Was the pressure regulator replaced also.
Fuel return lines pinched??
Old 11-09-2004, 09:08 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
The CPI injector includes the fuel pressure regulator on the side of it.
Did you also replace the internal fuel lines in side of the plenum?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-11-2004, 10:15 PM
Re: Re: problem with a 4.3 CPI
to blazerLT the injector and the return fuel line (that hooks to the side of the injector) yes
Old 11-11-2004, 10:32 PM
BlazerLT's Avatar
AF -Advisor
Those two fuel lines go to the injector.
One is to supply the injector with fuel, the other returns the excess unsed fuel back to the tank.
There is two of them and they come as a pair. They are called the "nut kit".
Old 11-14-2004, 02:59 PM
thanx Blazer LT
Old 11-14-2004, 04:17 PM
BlazerLT's Avatar
AF -Advisor
No pleblem, love to help.
