Old 11-09-2004, 03:35 PM
duranrp duranrp is offline
Reading the Ecu
OK heres the deal i got my car back from the garage, and the dumbass couldn't get my car to start. But when i looked at my dist.cap the rotor was even on at all, im talking no screw was holding it in. This happen over the weekend driving back from orlando. when my car had just shut off on me during the way back. So i went ahead and bought a new one. After the install the car started right up. But the check engine light stayed on and the car was sputtering during accelartion. And when i turned it off and on the ecu was flashing 8 times if im reading it right. The book says its the tdc position. I wanna know what should i do to fix the problem. thanks richard
Old 11-09-2004, 03:40 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
did the screw come out of ur dizzy?? if not its still inside spinning around and maybe causing damage. either that or ur firing order is wrong if u touched that, or ur timing belt jumped a tooth
Old 11-09-2004, 04:34 PM
Hhhmmm
While the screw is gone thats why i replaced it i dont think its still in there. The firing order is correct. But when i talked to the mech at the garage where i got my car looked at he had said the timing belt had jumped some teeth. But i assumed he fixed that when he put the valve cover back on. But maybe he didn't adjust the timing. But will the ecu spit out a code to keep the enigne light on just for the timing to be off? thanks richard
Old 11-09-2004, 04:35 PM
1PhatCX's Avatar
i think it would
also make sure that screw is not floating around inside ur dizzy
Old 11-09-2004, 04:57 PM
DirtyD777's Avatar
DirtyD777 DirtyD777 is offline
Send a message via MSN to DirtyD777
hey not to hijack this thread but maybe you could answer this for me 1phatcx..I ordered a new dizzy rotor but in the picture it looked dif. than the one in my dizzy now (it was round looking and the one i have now is like a bar with a hole in the middle..bad description i know..lol) is that just how the newer rotors are made?
Old 11-09-2004, 05:34 PM
1PhatCX's Avatar
nope, as far as i have seen they are all round
and i work in an auto parts store, all of them have been round
