Old 11-09-2004, 02:31 PM
Phoenix87 Phoenix87 is offline
Question Headlight motor electric problem
I replaced the headlamp motor actuators and reassembled the motors, but the passenger side motor is not getting electricity. I know it works because I tried plugging it into the driver's side plug. Any body have any suggestions?
Old 11-09-2004, 04:20 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Headlight motor electric problem
Have you checked the wiring to the Passenger one and what year is this car. Also welcome to the forum.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-11-2004, 09:53 AM
The year is 1987. I checked the wiring. It seems to be okay. The first time I hooked up the passenger side headlamp motor, I didn't have the brushes in correctly and it may have shorted out. I checked the fuses under the dash - they were all fine. Is there another fuse somewhere?
Old 11-11-2004, 11:35 AM
99onI95's Avatar
99onI95 99onI95 is offline
I know this is going to sound bad because I've put many thousands of dollars in my car. I had the same problem my motor works but its not getting any power. I spent a lot of time pouring over diagrams and voltage meters and everything else and could not fix the problem. So after a while I was willing to try anything. I simply got a wire tapped into the drivers side motor and wired it into the passenger headlamp motor. I hid the wire and haven't had any problems since. No blown fuses or anything. The only complaint is when I turn my headlights on there is about a 5 second grinding noise from the passenger headlight because the motor continues to run.
It might not be a proffesional fix but its cheap and it works. Good Luck.
Old 11-11-2004, 05:21 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
have you replaced the relay? my brothers 86 needed a new one on the passengerside.
Old 11-11-2004, 05:36 PM
FormulaLT1's Avatar
Fight the powwa!!!
I believe they meant relay by actuators but thats what I would think that would be the problem but since its only one side I would use a continuity tester to make sure the wire's are not broken in some spot you can't see and if thats not the problem I would check to seeif the motor where getting 12 volts at each side with a voltmeter.
Old 11-12-2004, 03:08 PM
Bad to the Bone
I decided to try 99onI95's advice. I tapped into the wires of the driver's side motor and flipped the switch. Both lights popped up at the same time. I could hear the intro of "Bad to the Bone" playing in my head. Thanks for the advice. It's greatly appreciated.
Old 11-17-2004, 10:13 PM
99onI95's Avatar
no problem glad to help.
Old 11-21-2004, 02:33 AM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Thats bad ju-ju.Why not just put a new set of relays in it,instead of rigging it .I see melting relays and oversized fuses in your future
