Old 11-09-2004, 12:04 PM
gaige gaige is offline
Rod torque specs
I was wondering if anyone knew the torque specs for the rod caps?
Old 11-09-2004, 03:39 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i can find the torque specs for you, but can you be a little more specific? i have an idea what/where the rod caps are. if you can describe to me exaclty what they are and where they're located, then i'll check the manual. I'm guessing they're the head bolts???
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
