Old 11-09-2004, 11:24 AM
S15S127 S15S127 is offline
No Wipers
I have a 1989 Firebird and the windshield wipers dont work. When u turn the switch nothing nothing happens. I checked the fuse under the dash and it was fine. Is there a relay or something that controls it???
Old 11-09-2004, 11:42 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: No Wipers
Yes wiper's use a relay. It should be a silver devise in your fuse box. If that checks out one of the wires is damage and you will have to test with a voltmeter and possibly run a wire. Good Luck and keep us posted. Also welcome to the forum.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 12-11-2004, 12:37 PM
Well I replaced the motor and nothing happened so where should start with the wires...................
Old 12-11-2004, 03:02 PM
Ok i checked the white wire at the switch and it has 12 volts but when i have the switch in any position none of the other four wires that go to the motor have any voltage. so i'm thinking that the switch is bad. Also the steering wheel will move up and down and the tilt thing works right, the horn doesnt work and neither does the cruise control. So I was thinking that I should just replace the whole steering column instead of trying to take it apart. Does anyone have any ideals???????????
Old 12-11-2004, 04:07 PM
CreepingDeath94 CreepingDeath94 is offline
Replace the switch first please...Jesus don't just slap a new steering column in there without checking/replacing switches first.
Old 12-11-2004, 05:03 PM
Ok how do i replace the switch then....The cruise control wires were cut so I fixed that. And also when I took the steering wheel cover off so I can see the horn wires, the red wire with the spring on it is'nt attached to anything does it just go into one of the holes??
Old 12-11-2004, 07:22 PM
silver87ta's Avatar
silver87ta silver87ta is offline
Re: No Wipers
Look for a black,short, wide plug, along the steering column. You'll have to actually get down in the floor near the pedals to look for it. I dropped the steering column in my 87 to pull the dash, and put it back up without putting this plug back together. Anyhow, I didnt have wipers, horn, or turn signals while this was apart, so, check that. Hope it helps.
02 Formula 5.7L V8 LS1
SLP Lid, SLP MAF, SLP Cold-Air Induction, WS6 ViS Carbon Fiber hood
Gone but not forgotten: 87 Trans Am 5.7L V8
My first true addiction
Old 12-11-2004, 09:48 PM
Well...........the black thing is plugged in so how does the stupid steering column come apart......... do i need to take off the wheel??? and does anyone have any clue why the thng will move up and down ???
Old 12-11-2004, 10:07 PM
silver87ta's Avatar
Re: No Wipers
if the plug is still plugged in then I'll assume that's not your problem, but if you still wanna drop the column, you need to start with the plastic shield that sits right under the driver side dash. After you pull that off, look for 2 13mm nuts on either side of the column (underneth, that is). After you take those, the column will swivel down.
Old 12-18-2004, 04:34 PM
82KnightRider's Avatar
82KnightRider 82KnightRider is offline
sorry si5s127,but I have to take over your thread. my passanger side wiper arm is leaving a 1/8 inch gap between the window and the blade so basicly the blade barely misses the windshield when turning.Before I break anything I was wondering if there is something I can adjust in the arm so the blade can actually touch the window while turning?thanks
Old 12-22-2004, 04:05 PM
Ok you can have thread, I wasnt really getting much help anyway. I'm sick of these damn wipers I think I'm just going to tie a string to them and run it in the car so i can just pull it to make them go up.......lol....of course then I wouldnt be able to make them go back down........
