Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 11-09-2004, 09:16 AM
jwing jwing is offline
Water Pump replacement on a 2000 Sunfire 2.2L
Need some advice on replacing the water pump. I bought the part, and can see where its at on the engine. Looks like I would need to remove 1 belt and the 3 bolts holding the water pump on. This sounds relatively easy and I'm wondering if theres anything else I need to watch out for.
Any help would be much appreciated.
Thanks.
Old 12-20-2004, 09:02 PM
mikec041 mikec041 is offline
Re: Water Pump replacement on a 2000 Sunfire 2.2L
little late but if you still need ideas.
loosen bolts on water pump pulley before removing fan belt.
removeing the alternator and bracket will give you extra room.
4 bolts hold pump to engine.
finger tighten pulley on pump and after you put belt back on tighten the bolts.
good luck
