Old 11-09-2004, 08:36 AM
crashflyer crashflyer is offline
95 BlazerS-10 turn signal indicator problem
The right turn signal indicator lamp stays on when the running/headlights are turned on. But flashes when the turnsignal is activated and goes back to a steady light when switched back. When the running/headlights are off the indicator works normally. All the fuses and bulbs are fine. I just bought the truck recently and it appears to have a new turnsignal stalk. The lettering is nice and white and does not reflect a truck with 98,000 on it. Any ideas would be appreciated.
Old 11-09-2004, 02:22 PM
riddick79 riddick79 is offline
Send a message via ICQ to riddick79 Send a message via AIM to riddick79 Send a message via Yahoo to riddick79
do u know if the turn signal assambley is OEM or aftermarket? it really sounds like the signal assembley to me.
Old 11-09-2004, 03:59 PM
JoulesWinfield's Avatar
JoulesWinfield JoulesWinfield is offline
Re: 95 BlazerS-10 turn signal indicator problem
Take a look at the bulb and see if both fillements are lit. Also make sure the bulb isnt installed wrong.
Youre not supposed to be able to put it in wrong but if there is a human involved its possible.
It sounds like the two signal wires, low and high might be swapped.
Old 11-09-2004, 06:15 PM
Fractured1 Fractured1 is offline
I would check the ground also...a bad ground can cause a host of problems...
Old 11-09-2004, 07:44 PM
Fireplug Fireplug is offline
2 things that could cause that and they are 1 the turn signal switch and 2 the headlight switch with the headlight switch being the most common problem
Old 11-09-2004, 10:48 PM
really, i have never had a problem with my headlight switch, did not know that. but good to know.
Old 11-09-2004, 10:49 PM
really, i have never had a problem with my headlight switch, did not know that. but good to know. mine has alway's been the turn signal switch.
Old 11-10-2004, 07:24 AM
found it
found the problem... the wire to the upper turnsignal rt side was grounding out. Thanks for the help.
Old 11-10-2004, 08:12 AM
thanks for telling everyone what you found
