Old 11-09-2004, 08:31 AM
nafai nafai is offline
Fuel Filter Replacement 98 K1500 5.7
I have the Haynes manual for my truck but in there it says that you need a whole kit to check the pressure of the fuel system etc. Can I just remove the fuse to the fuel pump, start up the truck and let it run out of gas instead? Thanks.
Old 11-09-2004, 08:41 AM
Fireplug Fireplug is offline
Re: Fuel Filter Replacement 98 K1500 5.7
What are you trying to do ? Do a fuel psi test or replace the fuel filter???
sure that would work and also remove the gas cap that helps to remove a pressure in the tank
Old 11-09-2004, 09:22 AM
I'm just trying to replace the fuel filter. I'm not really worried about testing the pump or pressure right now. Thanks for the quick reply!
Old 11-09-2004, 08:32 PM
PigPen5150 PigPen5150 is offline
Send a message via AIM to PigPen5150
If you're just trying to replace the fuel filter, all it takes is a 19mm and 15 mm wrench.
