Old 11-09-2004, 06:56 AM
Alexxn 00 Si Alexxn 00 Si is offline
Pitman arm install ?
Hey everyone, my 2000 Blazer with 73K has had everything replaced except for the Pitman arm and it's a little sloppy sooo......how bad is this job ? Does the steering box have to be removed or can it be turned on its side without removing the hoses to replace it ? I can get a puller and I do have air tools as well.
Anyone ?
Thanks !!
2005 Chevrolet Silverado 2500HD Ext cab
Old 11-09-2004, 04:04 PM
JoulesWinfield's Avatar
JoulesWinfield JoulesWinfield is offline
Re: Pitman arm install ?
I would advise searching on this topic.
Heres what I understand.
Yes you have to remove the steering box.
Yes, you have to use a puller that will not damage the teeth on the spline.
It is a sucky job but, take your time, be carefull and its not that difficult.
Good luck.
Old 11-09-2004, 05:09 PM
Fractured1 Fractured1 is offline
ditto...but well worth it
