Old 11-08-2004, 09:00 PM
crewcabhallin crewcabhallin is offline
Send a message via AIM to crewcabhallin
Question bad cold starts
I have a 1995 crew cab 350 with a 7.3. its has bad cold starts with lots of blue smoke slight skip in the morning, good compression also has very poor fuel mileage no check engine light. please help me
Old 11-16-2004, 07:18 AM
who fan who fan is offline
Re: bad cold starts
Sounds like a normal cold diesel to me. Diesels don`t like being cold. Common cold weather start up.
Old 11-16-2004, 09:25 AM
*rake* *rake* is offline
Re: bad cold starts
Does it have a block heater & if so do you plug it in at night? If not get one & use it. This should help it not be so grouchy on those cold mornings.
Old 11-17-2004, 08:19 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
Re: bad cold starts
as for poor fuel milage, change the fuel filter and run some power service through it. otherwise, as for the cold starting, i own 2 diesels, a 2000 powerstroke, and a 85 6.2 detroit. They both seem to start off about 4 cylenders when first starting, but if you have original glow-plugs, I would replace those along with a new glow-plug relay. You have to take off the valve covers to get to the glow-plugs, so make a day of it.
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
Old 12-03-2004, 06:04 PM
i got the problem the cat was cloged and their was a lose injector. Before i had it fix i used 2 put the gas pedal to the floor an it would go! But when i put the pedal to the floor now i get a 100ft slap of rubber behind the truck
Old 04-13-2005, 06:02 PM
gbic1 gbic1 is offline
What is a loose injector, a leaking injector?
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 04-13-2005, 08:16 PM
ModMech's Avatar
ModMech ModMech is offline
Re: bad cold starts
Well it surely was NOT a "loose" injector, if the injector hold-down bolts are even the slightest bit loose, they WILL leak oil into the fuel, and you will need new injector o-rings to fix it.
Yes, a clogged cat will do this.
Detroit NEVER EVER made any engines for light duty vehicles for GM or anyone else. The Olds 5.7L, and GM 6.2L/6.5L engines were NOT made or engineered by "Detroit Diesel", but by GM of which Detroit Diesel WAS a subsidiary.
