94 cavalier dies when i brake.
I was driving down the highway today when i braked to come to a stop. when my 94 cavalier, made this chuging sound and lurched a bit when the engine just cut off. I tried to start it up agian, and as soon as i put it into gear is shut off again. After another try i got it running again, but it wasn't very smoothly. I pulled into my work and got out. I just fixed the back brakes, and the front one were done in may. also the abs light came on when it died. Please help. any suggestions will do me a world of good.
Re: 94 cavalier dies when i brake.
with your abs light on you could have a spun gear in one of your motors of your abs. i know it is about 250-300$ to fix in mine so i dont know how much it would be for you. but i know it is about a 3 hour job for a machanic to take everything apart and then to put all the new 'fancy' stuff back in but i dont know why you would have stalled!
my car kind of went cluck cluck cluck cluck dead. with this jerking feeling as I braked.
need more info.
When you came to a stop did it seem like the trans was stuck in gear?? because that year the TTC switch is a known problem. Lets not look at brakes just yet. When you start it up does it take a long cranking time before if fires up (starts) When it starts does it idle?? stall? rough idle?? cel on ?? Last tune up done ?? fuel filter done??? |
my last tune up was in july. and as for the fuel pump being checked im not 100% sure on that. When i first turn on my car it does take a long cranking time to fire up. then it just idles for a bit. My machanic took my car and it seemed to run fine for him. But of course on my way to work today it pulls this on me. I was coming onto the off ramp for the freeway, braking to make a stop to turn right when it suddenly died on me.
and yes it seemed like the trans was stuck
94 cavalier dies when I brake
100% sure it's the switch. my 94 did the exact same thing a couple years ago and it's the switch. the way the mechanic explained to me is that when the car starts moving the switch engages and when it comes to a stop it's supposed to disengage(something to that effect)but rite now it's not disengaging like it should. hope this helps
I love humanity. It's people I can't stand.-Gil Grissom Check out My NEW 2007 Cobalt LT "Pheonix" @ Car Domain |
The switch is call Tcc It locks the trok converter in gear while at idle and and will stall the motor. Its like letting out the clutch with the ebrake on and you other foot on the brakes the car cant move and stalls out.
heres my smart ass reply... did u push the clutch in lol?
i love my new sound system... Alpine type R 12" sub, Alpine deck, and MTX amp 2001 Z24 cavi, and it owns
to see if that is the problem disconnect the wires down on the transmission and see if it runs better.
Big Dude1 SHUT THE F##k UP |
Gee, I've been wondering why those wires were just dangling from the transmission. It's been like that on mine since I bought it last year.
Which is it - a TTC switch or a TCC switch? |
tcc tork converter clutch
Thanks fireplug!
fireplug that was harsh..
it seem to be TCC solenoid problem. goob luck
