Go Back   Automotive Forums Car Chat > Mercury > General Discussion
Old 11-08-2004, 05:53 PM
droopydog droopydog is offline
need advice on a 91 capri
Hey, just joined. I was hopeing somone may have had the same problem that I am having with my Capri. It's been studdering driving down the road and then started droping the idle at stoplights. Also when I first try to start it, especialy when it is cold out, it will start rev up a bit then die. IF anyone has had this problem, or knows how to fix it PLEASE HELP! I've put in new plugs, wires, roter,cap, O2 sensor,hade a valve job done a few month ago. Thanks
Old 11-21-2004, 08:48 AM
XR2KindOFgal XR2KindOFgal is offline
Send a message via AIM to XR2KindOFgal
Lightbulb Re: need advice on a 91 capri
Well, if I were you I would deff. replace the airfilter. When my xr2 was being "pissy" with me, I had it replaced, and we were good. Maybe try and oil chane. Check that the gas lines are hooked up good and tight too. GOOD LUCK! http://members.cardomain.com/ladyracer1
~*~Kayla~*~
