Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 11-08-2004, 05:14 PM
kamikaze_k77 kamikaze_k77 is offline
ABS Prob!!
I have a 95 monte Z34, and i am having a problem with the ABS. The ABS light is on although the brakes seem to work fine. Once in a great while, the ABS will kick on for no reason during low speed braking - in perfect weather. Anyone got any suggestions on what direction to go???
Old 11-17-2004, 12:23 AM
EdTee EdTee is offline
Re: ABS Prob!!
Go to the parts store like Kragen, Autozone, PepBoys and find out how to borrow their OBD scan tool. Autozone makes you buy it, you use it, then return it for refund. This is to get around Calif. law. Once you get the scan tool, follow the directions and scan the ABS system. It should tell you what wheel sensor is bad or other problems.
Old 12-10-2004, 07:26 AM
motumbo motumbo is offline
Re: ABS Prob!!
I had the same problem just fixed. It was a bad wheel sensor.
These Montes all have common problems. I better make a list and get them fixed before my extended warranty runs out.
Old 12-15-2004, 11:15 AM
linn9585 linn9585 is offline
Send a message via Yahoo to linn9585
I am having the same problem with the anti-lock light coming on but normally I am able to put it in park and restart it and the light won't come back on
Old 12-17-2004, 12:22 PM
MNMonte's Avatar
MNMonte MNMonte is offline
Re: ABS Prob!!
Do what I did and just pull your abs fuse! I was having tons of ABS problems and the dealer wanted $1300 to fix it. I said NO WAY! My brakes actually work better with the ABS fuse fulled, but if you live where there is snow you better know how to pump your brakes!
Old 12-30-2004, 10:56 AM
dj_skidoo dj_skidoo is offline
Send a message via AIM to dj_skidoo Send a message via MSN to dj_skidoo
Re: ABS Prob!!
How long does it take to switch out the left front abs speed sensor on a '96 z34
Old 12-31-2004, 03:40 PM
HellzX HellzX is offline
Send a message via MSN to HellzX
Re: ABS Prob!!
Usually the problem lies within the speed sensor. These are fairly easy to replace out, maybe take you 2 hours for someone who knows nothing.
Get a good multimeter to see what the impedence is, find the sensor that's garbage, then replace it.
