Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 11-08-2004, 03:53 PM
LVLOU LVLOU is offline
B2200.....won't start
Have a 1988 B2200 p/u....replaced battery, starter, and alternator.....still won't start....have power but when I turn the key nothing! ...any suggestions?...thanks
Old 11-13-2004, 06:52 AM
89B2200 89B2200 is offline
Send a message via AIM to 89B2200
Get a jumper wire to jump start the starter solenoid. About 3 ft. long.
Put the truck in neutral.
Engage the park brake.
Chock the wheels.
Turn the ignition switch on
Put one end of the jumper wire in positive terminal of battery.
Put the other end of jumper wire to starter solenoid to start the engine.
Once started, remove the jumper wire. This is momentary only.
If it starts, then your ignition switch starter contact is bad.
If it does not start, your starter solenoid is bad.
Old 12-22-2004, 02:07 PM
Av8rTX Av8rTX is offline
Re: B2200.....won't start
Alos check the neutral safety switch on the clutch
Old 12-29-2004, 03:21 PM
shedubie shedubie is offline
try checking the 80 amp fuse. mine went out on me and it wouldn't start either.
