Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-08-2004, 01:17 PM
ddubb5150 ddubb5150 is offline
95/96 Eclipse Engine Swap = Problems, wont start ...
Okay, I dont actually own an eclipse, but ive been working with a friend to get his working.
He had a 1996 Eclipse RS 2.0 Manual, and it was sitting outside of his house a couple months ago until somebody set it on fire. The whole back half was destroyed but everything in the engine compartment looked good ( with the exception that the firemen may have sprayed water in that area )
So we picked up a 1995 Eclipse RS 2.0 Automatic with a knock in the engine for $500. It started up and everything, just had a knock.
We decided to take the engine w/ manual out of the 96 and put it into the 95, so we also swapped the entire engine wiring harness + computer, etc, into the other car. There were a couple wires that we had to make a new connection for between the dash, and swap over the clutch and everything else, no problem.
What the problem is now, is that it wont start - the engine cranks over, but it has no spark. So I did a voltage test at the coil pack and the fuel pump, and it looks like wen you turn the key to the "run" position, it cranks 12 volts for a second, then 0 volts.
Same when we are turning the key .. it keeps switching between 12 volts and 0 volts, and since its both at the fuel pump and coil distributor .. im guessing it may be a computer related issue ??? Either the ECU itself is bad, or some kind of relay isnt staying closed ( bad ground ? )
There is also a small high frequency buzzing sound coming from the ECU inside the engine compartment when the key is in the run position.
Does anybody know anything about what we're working on here ??? Id appreciate any help possible, this project shouldnt have taken more than a weekend, but now we're dealing with some kind of electrical problem.
Thanks for any help in advance
- Dan
Old 11-10-2004, 11:46 PM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
Re: 95/96 Eclipse Engine Swap = Problems, wont start ...
same shit with my 96 RS i changed everything. Still wont start and its been like 4 1/2 months in our shop. Y dont you take it to the dealership? haha if i find out what is its ill let you know.
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
Old 11-13-2004, 10:23 PM
We've fixed the problem .. it was an electrical connector near the bottom of the engine we had to search for. After that we gave it a few cranks and it fired up.
Sounds like you missed something along the line if the car hasnt been working for the last 4 months.
- Dan
Old 11-13-2004, 11:05 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
you still havent got that thing running hella?
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 11-14-2004, 01:33 AM
haha hell no still not running So if Dubb says what he did worked then i have to try the samething. =\ Wish me luck man. Ill have pics of my car up soon.
Old 11-14-2004, 01:35 AM
- Dan
what connector was it? Can you take pictures or something. Its been like... 6 months now that my car won't start. =\ Yours is a 420A motor too tho right...?
