Old 11-08-2004, 12:09 PM
StEaLtH1991RT StEaLtH1991RT is offline
Unhappy big problem :(
i own a 1991 dodge stealth R/T TT and i just put insurance back on it to start driving and well it was sitting there for the past 2 months i did a spark plug change and nothing else to the engine but 2 day first time its really been drivin around it jumps like jurking when u let tha clutch out in 1st gear then 2nd does it less but still can tell 3rd it dies down but its still can be felt i was driving 2 day and i noticed a weird sound coming from the rear end well it was jurking it doesnt do it when u push tha gas only when tha clutch is fully out and no gas any other time its fine i have no idea what it could be only thing i could figure is vac hose was put on the wrong spot and the engine was jurking but i was watching tha tach and it doesnt seem to be jurking up and down stays but if i have it outta gear and just rev the engine it revs up dies down revs up dies down so i beleave somthing with the hoses hopefully its an easy fix if anyone has had this problem or knows what might be wrong please let me know thanks.....
Old 11-08-2004, 01:16 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
Re: big problem :(
Hmmm maybe your clutch could be going??? have you done the 60K tune up??
Old 11-08-2004, 01:48 PM
Igovert500's Avatar
blue + red light magnet
Re: big problem :(
Punctuation is your friend first off...if we can read your posts...we can help you better.
Is your plug going into the MAS plugged back in...
You mentioned you changed your plugs...did you change them just now or 2 months ago?
Do a pressure test to find vaccuum leaks(read FAQ if you don't know how to pressure test)
Now are you sure you just aren't used to the clutch again...I mean it's been 2 months.
As far as jerking, do you mean that it jerks a bit if in 2nd or 3rd gear but you aren't giving it gas...becuase if it is in gear, and you give it gas and then let off, it should jerk back a bit, because the gearing is slowing you down.
I'm having a really hard time figuring out if you have one problem or 3(engine reving, car jerking, noise from rear)
Are they related or not? Seriously seperate your sentences as it helps us help you.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-08-2004, 05:38 PM
mike93vr4's Avatar
mike93vr4 mike93vr4 is offline
Re: big problem :(
i could be spark blow out did you ck the spark plug gap befor u put them in
Old 11-09-2004, 11:23 AM
Re: big problem :(
sorry about not writing it good but was in a hurry well i put the bosch 4 spark,spark plugs so cant gap them. but if i give it gas it doesnt jurk at all but, i can tell even in third gear that its jurking but it seems to stop when i press the gas.as far as the engine reving i think thats the whole problem,well i figure if it does it when i hit tha gas with the clutch all the way in and it seems to not wanna stay at the right rpm it goes down up and such, so i think when i am driving the engine is doing the same thing...
Old 11-09-2004, 03:28 PM
Igovert500's Avatar
Re: big problem :(
So the car is just reving up and down for no reason?
1. Is your plug going into the MAS plugged back in...
2. If it isn't your plugs, then it is most likely a BIG vacuum leak(probably audible) but an intake pressure test would be the best way to locate one
3. O2 sensor gone bad
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-09-2004, 03:33 PM
10sec-Hopeful 10sec-Hopeful is offline
You could have put your spark plugs in backwards. I did that in my S-10, pistons were firing 4-3-2-1 instead of 1-2-3-4...piston one would be down when 4 is firing....and I had the exact same problem. I'd check those first. I'm guessing your 02 sensor is bad though. Get it checked soon though, could be bad.
Old 11-09-2004, 03:55 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: big problem :(
How can you put your plugs in backwards, do you mean the wires?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-09-2004, 03:57 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i'm just as confused as Igovert. Although punctuation did help a little bit, i still can't tell what is related, what is not. can you slow down a little and just tell us slowly what happens when you start the car? what happens when you put the clutch in? let the clutch out? give it gas with the clutch engaged? give it gas in neutral?
its just REALLY hard to diagnose without a clear understanding of what is going on. IMO, it sounds like what happens in every car when the driver hasn't driven stick in a while, or ever. When i first test drove my car (before i purchased it), i complained that the clutch was a little 'grabby' and it jumped and jerked when i let the clutch out. Well...turns out i just hadn't driven stick enough to make the smooth transition from letting the clutch out to giving it enough gas. Practice made perfect, though I must continue to practice everyday to keep the skills up!
just my 2 cents
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-09-2004, 04:02 PM
Linebckr49's Avatar
Re: Re: big problem :(
ya he must have meant the wires. there's no correlation between a plug for a certain cylinder, just the type of plug for the car/application. Ya, if you really wanna screw up someone's car, or just mess with em, you can switch some of the plug wires so the car will misfire and then it will definitely jump/jerk. HOWEVER, [just to cover my ass] i am NOT encouraging this in anyway, and i do not know what it will do, but it can't be good.
93 3000GT base
Old 11-09-2004, 05:22 PM
Igovert500's Avatar
Re: big problem :(
Well all the wires are specific sizes though...so it isn't easy to mess that up on our cars.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
