Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 11-08-2004, 10:16 AM
smonaldo smonaldo is offline
Heating problem
Ok, vehicle gauges say that all sytems, temp ok. Cannot seem to stop hot air from coming into the vehicle regardless of what temp I set the control on. Using the AC only helps a bit, and it doesn't seem to be affected by changing the TEmp setting control. In cooler weather, there does not seem to be enough heat. 2000 SLT model. I there still a Temperature control valve that regulates the flow of hot water into the heater coil? I suspect that it is malfuntionong or not getting a proper signal form the Control panel. I also suspect that is in a partially opened state, which explains why I cant get cool air out when I want it. Is the system pneumattically or electronically controlled? I looked under the hood briefly and could not locate a hose going into the firewall, but I really didn't look thoroughly. Any suggestions?
Old 11-08-2004, 10:50 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Heating problem
Blending door and the temperature control could be both faulty.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-09-2004, 06:25 AM
Ok, I'm with you on this one. I read some where on this sight that access to the blending door was behind the glove box, correct? Also, is the control electrical or vacuum controlled?
Old 11-09-2004, 04:09 PM
BlazerLT's Avatar
AF -Advisor
Re: Heating problem
Grab yourself a Hayes repair manual.
