Old 11-08-2004, 10:55 AM
superman0604 superman0604 is offline
Downshifting
I have an automatic transmission and when it downshifts it makes a loud thud and jerks the car. What could be the problem.
Old 11-08-2004, 11:43 AM
stfuad's Avatar
stfuad stfuad is offline
Send a message via AIM to stfuad
Re: Downshifting
Might be the transmission/motor mount(s) check to see if they've gone bad.
Old 11-09-2004, 08:59 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Downshifting
or yo ucould not know hot to drive anr arent heel/toe double clutch down shifting. if yo udont reve the engine up before letting out the clutch you will jerk and hte enigne will slow yo udown, let the clutch out smoother to save your brakes and your hcest form seat belt bruises.
Old 11-09-2004, 10:06 PM
Kven's Avatar
Kven Kven is offline
Re: Re: Downshifting
***its a automatic...
i dont know much about autos but have you checked transmission fluid?
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 11-10-2004, 10:23 AM
RandomTask's Avatar
RandomTask RandomTask is offline
Banned
Re: Downshifting
What type of car is it? (I need to figure out what tranny)
Downshifting should not be the main way to stop a car. Downshifting is used WHILE braking. You always want to do your braking in a straight line. This allows for optimal traction. If you are in the turn while breaking it will load up one wheel for traction (usually causing you to plow into the turn) You don't downshift while in the turn because this can cause loss of traction as well and cause you to spin out/loop the vehicle.
