Old 11-08-2004, 09:35 AM
mercurysniper mercurysniper is offline
Send a message via AIM to mercurysniper Send a message via Yahoo to mercurysniper
New Tires
Greetings Everyone,
Hope you all had a great weekend!
I just recently bought some new tires for my 2000 1500 Ext Cab Z71. The original tires were LT245-75-R16 and I upgraded to LT285-75-R16's. My question is, what is the proper tire inflation pressure for these new tires? The information for the stock tires is on the drivers side door panel, but not for any upgrades. If anyone has any information I would greatly appreciate it.
Old 11-08-2004, 09:45 AM
chuck16's Avatar
chuck16 chuck16 is offline
Re: New Tires
Shouldn't the proper inflation of the tire be on the actual tire?
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 11-08-2004, 10:02 AM
Re: New Tires
Yes...it is, for a specified weight, which is sometimes not correct for the current application.
Old 11-08-2004, 10:03 AM
gschretter gschretter is offline
Same as before.
Look at the pressure reading on the inside of the driver door.
Most of the time regardless of tire size the pressure should be the same for your truck.
My is:
50 psi in front
80 psi in rear
I have mine at 45 psi.
Old 11-09-2004, 12:19 AM
silveradoman silveradoman is offline
Re: New Tires
I have my rears at 35 right now, it was showing uneven wear (only the middle of the tire) and the fronts are at 45, I havenīt loaded it much in a while and the threads look good.
Old 11-09-2004, 06:44 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: New Tires
I put around 35 in all of my tires. They hardley wear at all, and still give good ride/handling and fuel mileage. Being as I worked at a tire store/service station for 9 years, this is the best all around pressure I've found.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 11-09-2004, 06:55 AM
Vortec327 Vortec327 is offline
Re: Re: New Tires
I always thought the pressure stated on the tire was the MAX allowable....not the recomended pressure.
Old 11-09-2004, 08:17 AM
deadmeat deadmeat is offline
The new tire pressure should be calculated relative to the load ratings of the old and new tires. What brand tires are the new ones?
Old 11-09-2004, 08:39 AM
Sivart Sivart is offline
Re: New Tires
Run around 35psi. This will be fine. If you carry a load or haul a heavy trailer you can bump up to 40 to 45 psi. I pull a 24ft camper and 45psi is perfect.
If you air up to max pressure you will feel every crack and pebble in the road.
Old 11-09-2004, 09:01 AM
Re: New Tires
Thank for all the information. BTW...The new tires are Bridgestone/Firestone AT Revo's.
