Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 11-08-2004, 09:32 AM
Boinggg Boinggg is offline
Shimmy in front....
96 BMW 740IL is starting to shimmy up front,sometimes it is barely noticeable and other times it is a little more harsher.Wheels are balaced and torqued.Anyone help?
Old 11-08-2004, 11:30 AM
libertylover libertylover is offline
Probably need to change the Upper Control Arm bushings, also known as the Thrust Arm bushing. Below is a website and you can see if the symptoms match yours. Note however, your car is an E38 and the one in the write-up is an E32 (older), so it may be a little different.
I did mine on my '93 740iL (E32) and it was pretty hard because it's difficult to get the bolts out.
Here's the website I mentioned: http://bmwe32.student.utwente.nl/
This site shows you how to make a special tool(s) to help with the job: http://www.nmia.com/~dgnrg/page_2.htm
I just bought new Upper Control Arms with the bushings already installed.
Here's a site for E38 stuff (lots!) Might be more data there. http://www.e38.org/
Old 11-08-2004, 01:43 PM
Re: Shimmy in front....
Thanx for your quick reply.I've had a feeling it could be that ,just wanted to see if someone else has had the same symptoms.Iknow they have never been changed so no harm in doing so.Thanx again.
