Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-08-2004, 08:33 AM
Rodeo98 Rodeo98 is offline
Question Error Code P1441
I know what the code P1441 states, but where do I start to look for the problem? Vehicle starts fine and seems to run fine.
Old 11-08-2004, 08:37 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Error Code P1441
http://www.troublecodes.net/isuzu/iszuobd2.shtml
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 11-08-2004, 08:45 AM
I know what the error code states, but don't know where to start looking.
The error code discription is not very helpful to me.
Old 11-08-2004, 08:57 AM
rodeo02 rodeo02 is offline
Most common cause for evap sytem purge codes is a bad gas cap. There is a check valve in the gas cap that can stick open & allow the tank to blow down (no positive press in tank). The evap system needs pos press in the tank. A new cap is like $3 at any parts store.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-08-2004, 09:01 AM
Thanks, I reseated the cap already will have to look closer.
Old 11-08-2004, 09:05 AM
The evaporative system, (charcoal box, hoses, solenoids, etc.) is under the rear of the truck, tucked above where the under-mounted spare tire goes. Check to make sure everything is connected, no cracked rubber tubing.
**Edit** reseating the cap may/may not have anything to do with this. If the check vlv is shot in the cap, it wont matter how tight you have it on, vapors will still leak thru the cap.
G/luck
Joel
