Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-08-2004, 02:10 AM
Glina Glina is offline
Angry Knock sensor again
1991, 3VZ-E - Problem returned. After changing the knock sensor wire averything was just fine - for two days. Now check engine flashes again showing knock sensor code - what could it be this time?
Please help ASAP!!!
Old 11-11-2004, 03:39 AM
ToyotaTech ToyotaTech is offline
Re: Knock sensor again
bad engine?
Old 11-15-2004, 02:32 AM
What do you mean?
Old 11-15-2004, 08:10 AM
the sensor is picking up a sound in the engine that it thinks at there is a knocking noise so it makes the timing of your engine fall back as to not damage it Maybe your engine is really knocking?
Old 11-15-2004, 08:14 AM
The engine is after complete rebuild, there's no knock in it, it's working with no vibration (almost).
Old 11-15-2004, 10:08 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
The ECM wouldn't give an error code for a sensor picking up an incorrect signal. The sensor doesn't know it's doing the wrong thing. It's in the sensor or the wiring or the ECM. Is it possible you damaged the wiring installing the intake manifold or something you needed to remove to access the knock sensor the first time?
Old 11-16-2004, 12:56 AM
To get to the knock sensor almost everything must be removed. There's hell lot of work to get to it, but i did. Brian R. - you gave link to page that said that it's almost imposibile to have knock sensor damaged. So I changend the signal wire (knock sensor itself is rather expensive). Everything was just fine - it had power like never, and than BOOM - check engine lamp again - checking for the ECU codes and I can't believe it - showing 52 - means knock sensor.
Yesterday I decided that either I can fix it or I sell my 4R!
Near the air intake there is that connector of this f***n sensor. I used a spray that cleans electronical connections.
Guess what - it works - well for now. We'll see for how long.
Best regards,
Thanks for help.
Old 11-16-2004, 11:01 AM
Brian R.'s Avatar
Resident Chemist
You're welcome - Good luck, I think you've found the weak point.
