Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-08-2004, 12:34 AM
LilEvtec94 LilEvtec94 is offline
Angry no spark on piston #3 !!!!
hey guys ok i jsut replaced my timing belt on my 94 civic coupe but the problem is that the third spark plug has no spark, we moved the spark plug to piston number 4 and there is combustion we checked the wire and yes it has a spark also. My dad removed each spark plug wire form the spark plugs and as u know u can see and hear the engine loosing power but with this 3rd piston it stays the same o and yeah my rpm gauge is tripping out it didnt use to do that about the spark problem i dont know if that happend after the timing belt replacement or before but i know the rpm gauge wasnt like that so if u guys have any ideas on whats wrong and maybe how to fix it that would be alot of help to me thanks.
Old 11-08-2004, 01:33 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
could be dist going
Team Lonely Drivers
Old 11-08-2004, 03:16 AM
rustymac rustymac is offline
Re: no spark on piston #3 !!!!
Your dead hole has probably nothing to do with your timing belt. Make sure your #3plug, wire and distributor cap are all in good condition. Make sure there are no cracks. Try running the car in the dark and look for the spark arcing from #3 wire.
Old 11-08-2004, 01:31 PM
thanks ill try that il let u guys know what happends
