Old 11-07-2004, 11:16 PM
dpetdog99 dpetdog99 is offline
Gauges
How hard would it be to swap a 'granny pack' to a 'ralleye pack' instrument cluster. Sorry, I'm still talking from my G-body days. What I mean is I have just the speedo with the idiot lights, and if I could find a real gauge cluster, how hard would it be to swap it into my LeSabre. It's a '95 Custom if that means anything.
I know GM says that later model radios won't work in the car, just wondering if '95 and later model gauge clusters would work in the car, and how hard it would be to swap them in.
Just thinking out loud, as usual. I just like having full gauges.
Have a good one!!
Dan
'95 Chrysler LHS, wrecked, see it here.
'95 Buick LeSabre Custom. 101,000 miles, 3.8, auto. Almost a bigger piece of shit than my LHS was!!
'01 Silverado 2500. EC/SB, 6.0/auto, 4x4. 60,000 miles. Of course it's not mine, it pop's.
Old 11-08-2004, 02:35 AM
avatar307's Avatar
avatar307 avatar307 is offline
Re: Gauges
Well... idiots lights are simply lights that are turned on by the ECM/PCM, either by appling power or ground. Gauges are continuously varied according to the voltage or resistance present on the sensor wire connected to whatever sensor that gauge monitors. I.e. Unless the wires already exist under the console, it's likely more trouble than it's worth. Depends on if the extended gauge cluster was available on the 1995 LeSabre Custom... probably wasn't.
"Sleeping is the only thing keeping me from killing all the stupid people on this planet."
"Of one that loved not wisely but too well;" (Othello, Act 5, Scene 2, Line 344)
Old 11-08-2004, 06:22 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: Gauges
You dont have coolant temp, oil pressure, rpm's, speed, voltage, and fuel on yours?
Old 11-08-2004, 09:10 AM
redly1 redly1 is offline
Re: Gauges
ebay has both a 95 (plain jane speedo only) and a 97 (w/gauges) gauge cluster. They appear to be the same shape/size.
95
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
97
EDIT: I guess it looks like the 95 cluster has longer bottom tabs. The 97 cluster says it fits 96-97 Lesabre. Hmm
here's a 93 Park Avenue Cluster
Old 11-08-2004, 10:36 AM
avatar307's Avatar
Re: Gauges
Right, they say it will "fit." Which means, "it will fit in the hole in your dash." That doesn't mean there will be any wires to connect to it, or the correct wires to connect to it. That all depends on the wiring harness behind there. If it was an option or even available on that model, then their is a change that the wiring harness includes those wires already, and there's a chance that those wires actually go somewhere. Only way to know for sure would be to pull the dash apart and sit there with a multimeter... or buy one and see if it fits and re-sell it if it doesn't... *shrug* Or buy it and run your own wires, LOL.
