Old 11-07-2004, 10:40 PM
Technical_Automan Technical_Automan is offline
Banned
E-Brake: From Strong to Weak. Help?
When I bought the car, the E-brake was perfect, locked the wheels with no effort as soon as the lever was pulled, but after 2 dry pavement round the corner powerslides it's very weak. Do you think it just needs to be adjusted? or do you think I broke something?
Old 11-07-2004, 11:08 PM
StealthModifier StealthModifier is offline
Re: E-Brake: From Strong to Weak. Help?
my e-brake doesnt work either, i can put it in drive an let off the brake an pull the e-brake all the way up and it wont stop it
Old 11-07-2004, 11:57 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Just tighten it up, I did mine yesterday. It only takes like 2 minutes, just open the center console and undo the 4 screws inside and take it off and tighten the bolt connected to wire.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-08-2004, 12:57 AM
mike93vr4's Avatar
mike93vr4 mike93vr4 is offline
is it weak or is it like pulling free like nothing
Old 11-08-2004, 11:14 AM
Banned
I'll try that Thorun...it's weak, it works but only a little.
Old 11-08-2004, 05:21 PM
so u just tighten that bolt in there? and can u get it too tight?
