Old 11-07-2004, 10:11 PM
heretic316 heretic316 is offline
Send a message via MSN to heretic316
94 3.4 v-6 egr valve removal
ok guys, just got a 94 with a 3.4 v-6 about two weeks ago.
the first problem i had was that when i test drove it evrything was fine, a couple days later, it shut off after running real rough as i pulled into the driveway. i think it may be the egr valve after reading these forums.
is there a way to remove it and block it without it throwing a ses light?
by the way, it was also bad low on power, took all day to get to 60 mph, so i cut off the cat and welded in a straight pipe, helped alot. but still have the rough idle problem especially after warm up/
anybody? anybody? bueller?
thanks guys
Old 11-07-2004, 10:19 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: 94 3.4 v-6 egr valve removal
well, that car has a computer on it, run it for codes, and the car will tell you whats wrong with it.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 11-11-2004, 07:57 PM
but can i remove it and maybe block it off with a plate and use a simulator for the 02 sensor
Old 11-12-2004, 12:47 PM
89IROC&RS's Avatar
if you are going to fix it, do it right, why guess at what you think it is and cause more problems? it might have nothing to do with the EGR. if you have the codes, it makes no sense not to run them.
Old 12-01-2004, 01:50 AM
chevy_chic20041 chevy_chic20041 is offline
Send a message via Yahoo to chevy_chic20041
Re: Re: 94 3.4 v-6 egr valve removal
You should find out what codes its throwing off for one thing i don't think the EGR valve will make it die that is the problem on my car and it just makes it run rough. The EGR valve is part of the emissions, it costs about 170 dollars
Old 12-01-2004, 01:18 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
the car dying after running rough could be a couple things. do as the guru suggests and check for codes...
*Better power-to-weight ratio than a C6 corvette*
