Old 11-07-2004, 08:48 PM
99eclipsegst 99eclipsegst is offline
help with boost gauge
i bought an autometer gauge with the nylon hose and im having trouble installing it. so i found this site http://www.plymouthlaser.com/bez.htm
i need help to determine what RTV is and where can i buy it. if no clue what it is. what else can i use instead of it.
thnx
Old 11-07-2004, 09:47 PM
joemathews's Avatar
joemathews joemathews is offline
Re: help with boost gauge
RTV is a gasket sealer substance sold in tubes at your local autoparts store. I followed much the same process as the dude in that tutorial, with the piece of rubber hose coming off of the Tfitting, then the nylon line stuck in the end of the rubber hose.
I didn't use RTV, and have had no problems with the gauge line blowing out (just make sure it's a tight fit).
1996 Eagle Talon
Old 11-11-2004, 05:37 PM
well i fanally finished installing my boost gauge today...yay.
i just a quick question. when i was done i started the car and reved it to see if the gauge was working but the needle did not move. IS THIS NORMAL? when driving it did read boost but only when driving.
Old 11-11-2004, 05:48 PM
o*HeR()'s Avatar
o*HeR() o*HeR() is offline
Banned
well if ur car is stock then maybe, mine goes up when i just tap the gas....maybe u have some lag
Old 11-11-2004, 06:28 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Does the gauge have vacuum? You won't be able to build any boost in neutral unless you do something unrecommended, like pinging off of the rev limiter. If it's a boost only gauge that starts at 0, it sounds like it's working right.
Old 11-11-2004, 11:11 PM
All i have is the stock turbo, k&n intake and apex'i exhaust. Yes, it is a boost gauge only.
